Hello Devon,
I don't believe that Trimble Access has previously been able to download an empty folder from the cloud. At least since Trimble Access 2018 when the direct integration with Trimble Connect was created.
It is great to hear that you are exploring using Connect Sync to upload files to Connect for delivery to Trimble Access. The intention is that Trimble Access can read directly from a Connect project and for those with a company server, Connect Sync is a good way to populate the cloud for data sent "To the field".
> Do you see any need for downloading empty folders in the "To the field" data use case?
The "From the field" data flow is currently handled completely differently and raw (field) data produced by the Surveyors is not uploaded to Connect in a way that Connect Sync can act on.
The recommended path for returning field data to the office is to use the Trimble Sync Manager - Scheduled Download to mirror selected field data into your Company server location.
See this section of the online help for details.
The Trimble Sync Manager download will reflect the folder structure from the data collector.
The intention of this approach is to move towards a task based workflow where the next action could be triggered based on status.
If I understand this post correctly you want to be able to predefine a folder structure in order to guide the Surveyors to create their survey jobs in a specific location on the data controller.
> Is this correct?
> Is it enough to guide job creation location or would you want to force that the specified location is the only available option?
> Do you need to specify this location to the individual Surveyor (eg. ~/FromTheField/crew1/*.) or would all of your crew's place their field data into a shared location (eg. ~/FromTheField/.*)
> Should different Surveyors be able to see each other raw data?
> Would you still need to have a system level understanding of tasks and the data packaged in each task?
Chay
Chay Froggatt
