I occasionally have the same issue when I use that command, but I haven't used it very much in the past year or so...
Currently I download the required work order from Works Manager via the web browser. Then drag and drop. But I just saw your comment and decided to revisit the command.
So if I visit the command WorksManager Work Order there is a 10-30ish second scan before the Field Data / Devices in Project is populated. Then it took the command 30-60ish seconds to populate the Work orders on Device field. It then took 15-30 seconds to populate a large grade check work order. It took me about 30 seconds to run the view operation, report didn't work, save as there was no delay, and import had no delay either. All of this was done on a very large airport job; focused on a data collector that holds the most work orders; and I tested it using a large grade check work order. This is way faster than I remember it being. It would be nice for the report button to work so that I can access the Site Works Report Utility; that it doesn't could be on my end and I need to reinstall the excel sheet in the correct location or check options to see that the operation is looking in the correct location.
Try cleaning up the data collectors by storing the older work orders in an archive folder off the device. Seems like the lag for me was in populating the fields so less might help. (data collector I checked had 431 work orders, for reference)
[Scott] [Threet]
[Flatiron]
