TDC-600 unable to connect to cellular - Not in Device Management Database
  • 1.  TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-16-2024 14:33
    We have purchased two TDC-600 data collectors and have not been able to connect to a cellular network. One of the devices is over a year old without success after multiple tech elevations at both AT&T and Verizon. One tech finally responded that the device IMEI# is likely not in the Verizon Device Management Database. This is something that would be done by the manufacturer. It was suggested I reach out to Trimble to have them register the device with Verizon. Any insight where to begin to get to the right department for assistance? Or if this is correct advice?
    Thank you.
    Christopher Coyle
  • 2.  RE: TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-17-2024 07:12
    Christopher,
    You should never go to a carrier for a SIM card for these types of devices. We always point our customers to the Data Activation Center (DAC). See here: https://www.dataactivationcenter.com/contact-us/. They understand these type of devices and can ensure that it's the proper plan. I would reach out to Chandy (see below).
    Logo, company name
Description automatically generated
            A picture containing text, device
    Chandy Sayre
    You had me at Hello…I love our customers!
    A PO Box 779 Clearwater FL 33757
    D (317)-449-4769
    P (317)-644-1286 (866)-966-8881
    W www.dataactivationcenter.com
    Zach Edwards
  • 3.  RE: TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-17-2024 07:17
    Thank you for the quick response!
    Christopher Coyle
  • 4.  RE: TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-17-2024 07:13
    The TDC600 is not a certified device with either of the carriers, as you've discovered.
    However, the team at https://www.dataactivationcenter.com/ will be able to provide you SIM cards and services which will work on your devices.
    If you have any further challenges, please reach out to your local Trimble reseller who will have local advice for you.
    Dan Colbert
  • 5.  RE: TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-17-2024 07:18
    Christopher Coyle
  • 6.  RE: TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-17-2024 11:39
    https://www.dataactivationcenter.com/activate-your-device-with-Chandy-Sayre/" title="https://www.dataactivationcenter.com/activate-your-device-with-chandy-sayre/" href="https://www.dataactivationcenter.com/activate-your-device-with-Chandy-Sayre/" rel="noreferrer noopener" target="_blank" class="fui-Link ___1rxvrpe f2hkw1w f3rmtva f1ewtqcl fyind8e f1k6fduh f1w7gpdv fk6fouc fjoy568 figsok6 f1hu3pq6 f11qmguv f19f4twv f1tyq0we f1g0x7ka fhxju0i f1qch9an f1cnd47f fqv5qza f1vmzxwi f1o700av f13mvf36 f1cmlufx f9n3di6 f1ids18y f1tx3yz7 f1deo86v f1eh06m1 f1iescvh fhgqx19 f1olyrje f1p93eir f1nev41a f1h8hb77 f1lqvz6u f10aw75t fsle3fq f17ae5zn">https://www.dataactivationcenter.com/activate-your-device-with-Chandy-Sayre/     Here is an easy form you can fill out if that would be helpful.
    Happy to help with cellular connectivity!  Chandy
    chandy sayre
  • 7.  RE: TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-18-2024 13:30
    We had used the Data Activation Center resource in the past for an older TDC150 that we had connection issues with. They quickly provided a SIM card that functioned properly.
    Good Luck.
    Mike Mike
  • 8.  RE: TDC-600 unable to connect to cellular - Not in Device Management Database
    Posted 04-19-2024 07:17
    Edited by Lane LeBlanc 04-19-2024 07:25
    Lane LeBlanc
