I was testing the TDC6 without any external receiver and the accuracy seems to be restricted, compared to the TDC600.
Wherever I was, the accuracy was stuck to 3.79m H / 2.5 V with 12 satellites. The TDC6 was unable to get any SBAS correction.
During the same test made simultaneously, the TDC600 went down to 0,75m H with SBAS and 26 satellites.
Is there a parameter to "unlock" the accuracy or is the accuracy of the TDC6 limited ?
Thank you in advance.
Emilien
Emilien Coustillas
