Hi Phil,
I've actually changed rolls with Trimble.
However, Lane LeBlanc's reply bellow about using the DAC is the best answer for getting the TDC650 connected to AT&T
https://www.dataactivationcenter.com/.
Regards,
Adam
Adam Wright
Sent: 07-19-2023 06:55
Subject: TDC650 cellular capabilities
Hi Adam,
I believe I am having the same issue as Michelle, Also, our account manager at ATT is unable to figure out what's causing the problem. Were you able to help Michelle?
Regards,
Phil Serpas
Sent: 01-19-2023 11:56
Hi Michelle,
I will contact you about the TDC650 and cellular provider issue you are encountering.
Regards,
Adam
Adam Wright
