Hi Doug,
Just realised that the link in the Esri community post doesn't work. You may need to contact Esri for advice on this. One question, are they using Chrome or Firefox? If they are using Enterprise and have a self signed certificate Firefox may not work. I searched for 'android 10 Amazon Root CA 1', that may also help.
Regards,
Mark.
Mark Kellaway
Sent: 12-13-2023 14:51
Subject: TDC650 Trusted Certificate error
Hi Doug,
Yes, the thread describes the issue in more detail but is because the client doesn't have the correct certificate installed.
Regards,
Mark.
Mark Kellaway
Sent: 12-13-2023 14:41
Thanks Mark. The error only occurs when using the TDC650
Not other devices. I'll take a look thanks for the info
Doug
Precision Laser & Instrument, Inc.'s Build Construction Division is Now Your Local BuildingPoint Ohio Valley!
CLICK HERE to Join Our Mailing Lists!
*This message and any attachments are intended only for the use of the addressee and may contain information that is privileged and confidential. If the reader of the message is not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any dissemination of this communication is strictly prohibited. If you have received this communication in error, notify the sender immediately by return email and delete the message and any attachments from your system.
Sent: 12/13/2023 4:33:00 PM
Subject: RE: TDC650 Trusted Certificate error
Hi Doug,
If the error is only within the Field Maps context then I would suggest that this is an Esri or browser issue rather than TDC650 per se. Have a look at this thread on the Esri Community, it looks like it may help.
Regards,
Mark.
Mark Kellaway
