You can go into the device settings and change the TerraFlex settings to disable location. Then when you run terraflex, choose the template, fill out your information, then Click Yes to store the Form without location. once synced open your Trimble Connect Map Workspace. Now you wont see a dot on the map because you didnt log a location, however you will see the form in the Layers window displayed as a number (number of forms collected for the template) to the left of the template name. Hope this helps. Now the only issue that may arise here is if you have TerraFLex Premium and the Offline GNSS enabled for field GNSS data post processing. If this is the case, then spin up a new project without the GNSS enabled and you should be able to collect forms with no locations and export as a csv file.
Good Luck, ericb
eric bock
Sent: 09-07-2023 01:25
Subject: Terraflex data capture
Thanks Hamish. Unfortunately whether the 'Form geometry must be captured' option is checked or not doesn't make any difference.
Any work arounds here?
Thanks Charles
Carbon Com5
Sent: 09-06-2023 19:58
Hi Charles,
There is no way to disable the location capture completely, but it should be possible to capture forms without being prompted to log a location. Have a look at the template in Map Viewer and see if the 'Form geometry must be captured' option is checked:
If this option is enabled then TerraFlex will require a location to be logged for the form to be saved
Thanks,
Hamish
Hamish MacMillan
TerraFlex Product Manager
