Thank and you're both right some context would have been ideal. So I have two devices, the 150cm and the DA2, hourly, which I want to figure out both using iOS and Android for the DA2. I have both TerraFlex and Esri products and sometimes I send people out with either/or depending on the situation. I do have a real-time subscription for a network so I can get corrections and I am not looking to do this offline. I have been watching the videos from
Frontier Precision and still think I did something wrong in my setup because the readings just don't make sense. The field maps set up from the video did work, but again I think my transformation might be off, working with NAD 83 (2011). I want to continue using the 150 with TerraFlex as well vs. the old collector. The most successful I have been with readings that did make sense was Positions with TerraFlex, but before I renew that license I wanted to see if there were any other solutions with the 150. I just feel like I am running in circles and could use a little more direction.
I uploaded my set ups with the user info whited out.
Kara O'Neill
Sent: 08-28-2022 19:02
Subject: TerraFlex displaying elevation
Positions is for post-processing (differential correction) of your TerraFlex or TerraSync field-collected data. You can collect accurate elevation data without but you would need a real-time correction source such as VRS or RTX. Like Norman said, there are a lot of details missing here such as receiver being used, accuracy the receiver is configured at (sub-meter, decimeter, CM), where you are working, if you have cellular in the field, etc.
Zach Edwards
