For the benefit of all, below are the answers to Alfred's questions:
1. Is there a way to get reference vector files from Connect to the Terraflex app?Yes, there are a couple of ways to go about this.Option 1: You mentioned the BETA feature 'vectorlayers on' - this feature is still in BETA and is still available to customers to use in that capacity. Please contact your local Trimble GIS distributor to get guidance to enable this BETA functionality. Because it is still in BETA, there could be limitations to its operation.Option 2: If you have a TerraFlex Advanced license, you can use the Tasks/To-Do workflow to select features within the Map Viewer, and create a task/to-do to send to the field. That task or to-do will display those features in TerraFlex Mobile. We have several customers that use it in this manner and simply make the attribute fields read-only so that field workers cannot edit the features if it is meant to be background, reference data.2. Symbology: We have received the enhancement request for customized or classified symbology, so know that it is in the backlog of items we would like to add in the future. Today, if you wish to differentiate features within background data, I suggest loading them into Map Viewer as different layers, so you can assign different colors that can be distinguished by the field user.3. Logging intervals:a. Right now the default functionality of 10 averaged positions is a set value. There is no way to increase or decrease the averaged positions. However, we are interested in feedback for use cases that require such customization. In our testing and feedback so far, 10 position averaging provides enough information to get a reasonable post-processed result while minimizing the toll on the field user. Does a user or organization gain significant value from the ability to choose how many positions are averaged for a feature?b. Same answer as above. The 10 positions is a set value. You may be remembering being able to customize or change this averaged position value inside TerraSync field software. A user can set a required accuracy within a form template, but not a required number of averaged positions.4. In order to make a field hidden to the field user for a project created in Trimble Positions, you can hide the field within the feature class Properties > 'Fields' tab > uncheck the box that makes a field visible before publishing the TerraFlex project.------------------------------
Lane Carter
Sent: 12-17-2021 09:14
Subject: Terraflex: Downloading vector reference layers to the app (Connect), logging intervals
Hi Alfred,
I will be reaching out in a direct message to answer your questions.
Lane Carter
