Hi Zach
Thanks for your input.
Regarding number 2 - Parts of our organization will not be using Terra Office but rather creating projects in Connect and will require the data in a GDB format for our GIS department to consume. We did not see the need for multiple users of Terra-Office. We have requirements to quickly set up and deploy field data collection projects without needing the effort of publishing via ArcMap . Also contributing to this is that not all staff are that clued up with using ArcMap and are not familiar with databases and schema rules.
Regarding number 1, From what you have said, any changes we need to make to a GDB will require us to republish a new project map. This will create problems if there are large projects with multiple users attached where a minor update in any of the domains is needed. Are there any workarounds to overwriting the .tmap in Connect with these updates?
Number 3 lets hope for a quick update from Trimble. also please do share your methods to working around no. 4.
One more thing if you can advise. We inadvertently removed/deleted a template from Connect. This template was created from a published GDB. Is there a place to recover it from or do we delete the map and republish?
Thanks
Keshlen Reddy
Sent: 09-11-2024 07:43
Subject: TerraFlex Enhancements
Regarding number 2, why are you exporting a GDB from connect if you have Terra Office? If you stay in the original GDB, you are in your system. Regarding number 1, you cannot make any changes to the GDB after publishing up to connect from Terra Office. I agree with number 3 and have communicated this to the Trimble Terra Office team as well. There is a way to do number 4 but it's not super clean. I will check my records and get back to you on this.
@Matthew Morris
@matth
Zach Edwards
