Steven,
Here are some things to try. First, make sure that you have NO draft forms in your list of forms (features) on the app. If you do, open them and submit/save them, as ANY draft forms will keep TerraFlex from syncing any forms until those drafts are saved. Second, make sure that you try a different wifi source rather than the one you are on. Third, be sure to be on the latest version of TerraFlex, as there was a release this week. Fourth, if you are using Tasks/ToDos, it could be hung up on that. Finally, logout and log back in. If that doesn't solve it, be sure to send a log file from TerraFlex to your distributor to work with Trimble on a support ticket.
Zach Edwards
Sent: 03-05-2024 17:17
Subject: Terraflex Forms Not Syncing with Trimble Connect
I'm having the same issue and receiving the same error message: "Cannot connect to server. Please check your Internet connection. Some images could not be sent." I cannot sync 217 forms collected over two days. Any help would be greatly appreciated.
Thanks.
Steven Mack
