How are Terraflex rules and mandatory fields supposed to work? We have a data capture form we uses annually - this functionality appears to have changed year over year. As part of environmental scientific research we are measuring trees. Where a tree is dead, we have a rule which then bypasses the other measurements, such as height. Last year this worked fine - on save the record was created without issue. Using the same form this year, it throws an exception where the fields have to be completed prior to saving, presumably because they are mandatory. Since we are using hundreds of volunteers to do these measurements, the usability and input rules are important in order to collect the data accurately and quickly. Is there a way to suppress the error message which forces the user to fill in data that isn't needed, yet still have the fields mandatory for the 99% of trees that are alive?
Thanks
Charles
Charles Nicholls
