Hi Guys,
I am about to start the condition rating work on the existing assets on the council. I have created 4 tasks from ArcMap using Trimble TerraFlex Add-in for Arcmap.
Everything is fine, all the asset classes are properly loaded and can be visible on TerraFlex.
The problem that I have encountered is that none of the Base Maps (Street Map or Satellite) load at all.
I even tried creating a Satellite basemap via Trimble Connect Web which can be see under Map Caches on TerraFlex but again nothing loads on when I select it.
Any suggestion and solutions are highly appreciated.
Thanks.
Abhishek Dhungel
