Hi Zach/ Matt
If TMM's not doing the job have them install GNSS Loader
Download the *.apk from here v1.0.20 HERE - copy to the device (email/cloud drive/ cable) and install via File Manager app
They could actually run this from the device If easier
Once Installed
- Run GNSS Loader > Install Accuracy option > Copy the code in and hit INSTALL
If there's not already a case with support I'd recommend submitting one so we can better understand what's going on with this specific device (or code)
Tom Harrison
Sent: 05-03-2024 08:08
Subject: TMM losing RTX license, Failed to add license
Matt,
I believe what Trimble is suggesting here is to install TerraFlex ONLY for the purpose of activating RTX. Then, TMM and ultimately your custom application should be able to use the Fieldpoint RTX corrections. It's an alternative way to apply RTX aside from TMM.
Mark,
Would you suggest that i send them the 1_0_19 build of GNSS loader to try to load RTX in lieu of TMM?
Lastly, we have confirmed that the issue is NOT the code. It's purely that the 650 will not take any RTX code via TMM currently. It is unique to 2-3 of over 200 in their fleet.
Zach Edwards
Sent: 05-02-2024 07:15
Matt,
I came across this same issue with the same error message using the latest TMM using a TDC650. We then loaded it via Terra Flex /settings/licensing successfully. It did take a few tries.
Lane LeBlanc
