We are currently using Trimble SDK and TMM app for Android/IOS for conecting with Catalyst Anntenna. We have received some "bad coordinates" (either with offset or scaled) and when I look into the metadata I can see that the error occurs when "outputReferenceFrame": "ITRF2014" while when "outputReferenceFrame": "off" the coordinates are fine. Here are some more meatdata:
"outputEpoch": "2023.7",
"sourceEpoch": "NaN",
"outputReferenceFrame": "ITRF2014",
"sourceReferenceFrame": "Off",
"antenna_name": "DA2, 6231100109: Trimble",
"isTransformed": false,
"geoidModel": "EGM96 (Global)",
"stationId": "0",
My settings in GNSS configuration are always the same:
For testing purposes I changed to other Reference Frames EUREF-DK15, ETRF2000, WGS84 (G1762) but I couldn't re-produce the error (it was always coming "outputReferenceFrame": "off" and good coordinates).
My question are:
1. Why I get only sometimes "outputReferenceFrame": "ITRF2014" while I am not changing anything in the configuration? When the "outputReferenceFrame": "off" which is the frame that is used?
2. What the "isTransformed": false means?
3. What are the correct settings that I should use in GNSS configuration? (We are located in Denmark).
I would also like if it's possible to provide me with the 7 parameters that are used for transformation between the systems, so I can try to re-process my data.
Thank you in advance.
ank ank
