Transform commandos in trimble drawing - Help
  • 1.  Transform commandos in trimble drawing - Help
    Posted 11-30-2023 10:05
    I used to working in Autocad connected to novapoint but now i use trimble drawing and its great. But i do need some help with the commando, especially one commando called "ADETRANSFORM" in Autocad. This commando made scaling, rotating and move in one commando because when you want to insert a pdf on a map and draw out existing waterpipes i could get a scale that was close to perfect but now i need to drag manually or use some commandos but its not as precise and ADETRANSFORM. Anyone that can help me?
    Best regards,
    Alexander Wallenbring
