Trimble Access to Trimble Connect integration
  • 1.  Trimble Access to Trimble Connect integration
    Posted 01-13-2023 03:42
    we are expanding our equipments with Trimble TSC7. Trimble Access already have an integration with Trimble Connect and I think that the integration from Trimble Connect to Trimble Access works very good.
    From Trimble Access and back to Trimble Connect is where the challenges begins. We have created a folder structure in the Trimble Connect folder structure that would work just fine on the TSC7 for importing and eksporting data to Trimble Access. On the TSC7 we put our job files in a specific folder in Trimble Connect and when we export different format (ex. JobXML file) we put them an Export folder. None of these files are we able to see in the folders in Trimble Connect. Instead Trimble Connect adds an ToDo element which includes some of the files we have uploaded from Access to Connect. Not all of them. If I open  Sync Manager then all the files are available. Instead (or in addition to the To Do element) it would be so much better if all the files created in Access which we put in similar folders to them in Connect would be syncronized from Access to Connect.
    I hope this was understandable. Adding som attachments to show the folder structure.
    Is this a feature that could be included in a update for Trimble Connect?
    That would reaaly help our dataflow to be much better and faster.
    Thomas
    Thomas Bøhlerengen
