I'm using a DA2 together with the TDC600 for daily field capture in Caribbean. We have a yearly subscription I believe. It may be more. 60% of the time, everything works fine for connectivity with satellites from 21 to 30 of them. However, there are days with total clear skies, not a single satellite would be available. This might happen for 2 days, then the next day everything goes back to normal. During the down time, if the TDC600 is switched to the DA1(integrated) all the satellites get connected instantly, which means it has to be a DA2 issue.
Is there an issue with the servers on your end? is there a way to verify online if the DA2 should have full connectivity?
There are times when the DA2 accuracy is needed and after travelling a long distance for data capture, the DA2 fails to connect to satellites.
Please help
Darton Charles
Darton Charles
