Hi Joe,
I actually didn't have any problems having data show up on the Connect website. But honestly, I consistently have issues with Trimble Connect either not showing data or not being able to download data. I try all the usual solutions - logging out, restarting my handheld, etc. One fix might be your filter settings. Once that was my problem - I had the filter set to a certain date, so my latest data wasn't showing up. You could try that. Otherwise, sometimes the problem seems to be magically fixed after a couple days. But sounds like you've already tried that! Good luck, and hope you're able to find a solution!
Sarah
Sarah Millus
Sent: 01-08-2023 09:10
Subject: Trimble Connect doesn't work
Arianna or Sarah, Admin too.
Now when I make corrections in my handheld (TDC100), and sync, the corrections don't show up in my Connect file. I spent two days now trying to figure it out. Is anyone else having these issues?
Joe Dman
