Understood. I get it. I would just plan on converting to Terra Office (https://geospatial.trimble.com/products-and-solutions/trimble-terra-office) before the end of the year, as Positions will likely not function after that. Curiously, are you using it in conjunction with TerraFlex or TerraSync (to produce DDFs)?
Zach Edwards
Sent: 02-15-2023 09:53
Subject: Trimble Connect How to Delete Multiple Fields
Thanks,
Zach, I will turn the fields off before pushing them up and try that. Unfortunately, Positions is what I have to work with.
Jaime Cardenas
Sent: 02-15-2023 08:19
Jaime,
you should be able to hide the fields in arcmap prior to creating the positions project. That will cause them not to go across to TerraFlex/TerraSync. Also, you should speak to your dealer because positions has been deprecated in favor of TerraOffice. It's very similar, but is rebranded and is a named-user login versus perpetual.
Zach Edwards
