Hi, everyone
I found out the other day that Trimble Connect is case sensitive when comparing BCF IDs.
For UUIDs, however, upper/lower case should not make a difference (Source: Complete guide to Universal Unique Identifiers (UUID) | UUIDTools.com)
I found this out by manually changing the ID of an issue. Trimble Connect only recognised the issues as the same if the ID was exactly the same. As soon as the case was different, Trimble Connect thought that they were two different IDs.
Could you fix this?
Cheers,
Lucien
Lucien Zenners
