Hi Vincent,
The general feedback from Connect Sync users has been that they want to remain signed in for long duration without logout, which seems to be working well in your case. If you see any concern with long duration logins, after the desired duration (e.g. logging off from work) , you can logout - so that the sync schedule is safe for your projects.
Darshan Rajaram Kamat
Sent: 02-27-2023 01:07
Subject: Trimble Connect Sync
Thank you ,
I had seen this, but I don't understand why I've been online for 12 days? I expected to have to identify myself after the 9 days
Vincent Dausset
Sent: 02-27-2023 00:55
Hi Darshan and Vincent
Regarding the Trimble Connect Sync user guide TC Sync will automatically keep you signed in to your account for 9 days (as of June 16th 2021).
Ole Christian Eidhammer
Sent: 02-26-2023 21:54
Hi Vincent,
As long as the user doesn't turn off the local machine and doesn't let it to be idle, the user will stay logged in for upto 5 days and sync operations can continue.
