Hi Sandy
80s or 90s and sunny should not be a problem for a Geo6000, but if the problem happens in the sun but not in the shade you're probably right about it being temperature-related.
Do you only have one Geo6000 unit? It's possible there's a temperature-related hardware problem one one unit although I can't imagine what.
There's a possibility that upgrading TerraSync to version 5.41 would help - there were quite a few stability-related changes between versions 5.10 and 5.41, some of those did reduce CPU load which would help with temperature-related problems. From my vague memories, there's no real advantage in upgrading TerraSync past the 5.41 mark - later versions were mainly done to support later receivers.
Alternatively, try using an external antenna and keeping the Geo in the shade.
Norman Smart
Sent: 09-07-2023 12:38
Subject: Trimble GEO XH keypad locks up
By warm weather, I mean in the 80s or 90s and sunny. The problem doesn't happen in the shade or during cooler weather.
It's a Grimble geoXH geoexplorer 6000 series
Terrasync 5.1
Sandy Kubillus
skubillus@ilmenvironments.com | ilmenvironments.com
110 Le Baron Street, Waukegan, IL 60085
Office: (847) 244-6662 | Cell: (847) 343-3484
Sent: 9/6/2023 6:16:00 PM
Subject: RE: Trimble GEO XH keypad locks up
I don't believe I've seen anything matching this description, but a bit more information may help someone diagnose the problem:
- What do you mean by "hot weather" - do you have any idea what the temperature was?
- What model of Geo XH? Geo 7x / Geo6000 / Geo3000 / Geo2008?
- What OS version and GNSS firmware?
- What application were you using?
- Any real-time corrections?
To see if it is an overheating problem, you could try using an external antenna and keep the Geo in the shade so it isn't heated by the sun.
Norman Smart
