We have today released a TMM update for Android, 2025.25, which addresses this issue, where a 'No internet' message appears if TMM is started while the device is not connected to the internet and there is no currently signed in user.
Mark.
Sent: 02-15-2026 13:44
Subject: Trimble Mobile Manager (Android) - Crashing without network connection
Neil, were you able to get this resolved with Mark? If not, one thing to try is to enable Wi-Fi and Bluetooth scanning if it's turned off within the location settings on android. If it's turned on, try turning it off. I know that this setting has been particularly problematic with certain android devices when using TMM.
Zach Edwards
Sent: 12-23-2025 13:42
Hi All,
I'll reach out to you directly @Neil Winn, and will update the group with any results. I have had some interaction with Support about this issue, so will try to close the loop.
Best regards,
Mark.
Mark Kellaway
Sent: 12-23-2025 11:01
Thanks Eric. I can rule out another receiver being the problem and provide some clarification. When I open TMM I am unable to select a receiver because the app attempts to open an external browser (webview) right away and freezes. Sometimes it is possible to close the webview and continue, but not consistent.
Neil Winn
Sent: 12-23-2025 10:18
i don't have an r12i to test. i would make sure the name of the r12i hasn't been changed. you can check in the webui. there were issues years back where the name of the receiver wasn't the same as what esri was looking for. if you had a different trimble device around i would try that out to rule out the t12 receiver.
Sent: 12/23/2025 12:12:00 PM
Subject: RE: Trimble Mobile Manager (Android) - Crashing without network connection
Thanks Eric and Zach. On my device I have followed your steps. I am using a R12i so no sign-in is necessary. With no internet connection, TMM still attempts to open a webview window and freezes.
I have sent a screen recording and log files from both apps to Duncan-Parnell support as they work on the issue.
Neil Winn
Sent: 12-23-2025 09:28
Following what Zach said, you can try this to get out of the looping/crashing.
- Go into your bluetooth setting and forget all Trimble GNSS devices
- Uninstall Mobile Manager and Field maps
- Reinstall moible manager and field maps
- Connect to Trimble GNSS receiver via bluetooth
- Run TMM, connect to Trimble GNSS and configure your GNSS Settings. Leave running
- Run Esri field maps, go into profile, and configure location provider and profile.https://www.youtube.com/watch?v=myTRdNGtG8c&list=PLUKFLYkxejVaHKQbbfnqvr-Ev0Xk_jw7g&index=12
- If you still have issues make sure you get both esri and trimble log files and send to Duncan.
eric bock
