> If you move the R1 while in safari, does your location move on the map?
No. However, if I move the iPhone the location changes.
> Also note that on iOS the position supplied comes directly from the attached R1 GNSS receiver, not from TMM (or GNSS Status).
Does it mean that it works without TMM or Status Utility software?
> If you connect the R1 to your iPad, then after around 5 minutes run GNSS Status and select 'Location Services' as the source, what do you see in GNSS Status for the accuracy?
I'll test it later.
> Do you have a device with a cellular modem in that you can use to test? I'll also test with a WiFi only iPad here.
I tested iPad with hotspot, iPhone with cellular, iPhone in airplane mode.
iPad with hotspot get 35m accuracy.
iPhone with cellular - 4m accuracy.
However, the position does not change if I move R1.
I disconnected the cellular, Wi-Fi, and Bluetooth - iOS continued to return some fake location based on accelerometer.
Please block Munir Ahmad above, it's spam.
Anton Zimin
Sent: 11-13-2022 19:44
Subject: Trimble Mobile Manager does not share location with Safari and Chrome on iOS
Hi Anton,
It seems that location services is making the 'choice' to not use the receiver location. I should note though that location services will only ever report a best accuracy of 5m, clearly you are not even achieving that. Also note that on iOS the position supplied comes directly from the attached R1 GNSS receiver, not from TMM (or GNSS Status). If you connect the R1 to your iPad, then after around 5 minutes run GNSS Status and select 'Location Services' as the source, what do you see in GNSS Status for the accuracy?
Thanks,
Mark Kellaway
Sent: 11-08-2022 10:00
You can see on my screenshots above that coordinates from Trimble are shared sporadically. They have consistent location and accuracy. However, most of the time iOS uses the Wi-Fi position.
Anton Zimin
Sent: 11-08-2022 00:24
It's likely working just fine but reporting an erroneous RMS accuracy. If you move the R1 while in safari, does your location move on the map? This is not that uncommon to see erroneous accuracy reporting when overriding location services.
Bibah Rayeq
