Go to page 59...My Document
Restarting or resetting the operating system
If your device becomes unresponsive, and the troubleshooting guide does not resolve the
problem, you need to restart or reset your device.
Restarting your (unresponsive) device
If your device is no longer responding to touchscreen or keyboard input, you may need to
force it to restart by removing power from the system.
NOTE – Restarting the system by holding down the Power key removes power to the CPU. Any
unsaved files and settings will be lost.
8 Troubleshooting ,downloading updates, and repair
TrimbleNomad5HandheldUserGuide|60
To force your device to restart, press and hold the Power key until the device shuts down
(~15seconds), then restart your device by pressing the Power key.
Resetting your device
If restarting your device does not resolve the issue that you are seeing, resetting it might
help.
You can remove all data from your device by resetting it to factory settings.
WARNING – A factory reset wipes all data from the device. While any data stored in
your Google Account will be restored, all apps and their associated data will be
uninstalled.
WARNING–Your device is protected top revent other people from using iti fit's
been reset to factory settings. To ensure that it's really you doing the reset, you'll need
to enter a Google username and password associated with the device after factory
reset. If you don't have this information, you won't be able to finish the setup process
and use the device at all after factory reset.
Erasing your data may take sometime, so make sure that you plug your device into a
power source before you start.
1. Open the Settings app .
2. Go to Settings / Backup & reset. You may need to enter your unlock pattern, PIN, or
password.
3. Tap Factory data reset.
4. Tap Reset.
5. If you have a screen lock, you'll need to enter your pattern, PIN, or password.
6. Tap Erase everything to confirm you want to reset the device to factory settings.
7. When the device has finished erasing, select the option to reboot your device
Lane LeBlanc
