I'm attempting to collect the meta data fields for each point location collected with ESRI Field Maps using a Trimble R2 dm and/or cm enabled receiver. I have the many GNSS meta data fields added to the feature class and visible. But after I collect the location the meta data fields are not populated. I'm working within an ESRI enterprise environment v10.8.1, I'm using an TDC600 Gen2 running the latest version of ESRI Field Maps. Any thoughts would be welcomed on what I might be missing.
MATT SHELLENBERGER
