  • 1.  Trimble rnss connections
    Posted 07-10-2023 18:56
    Hi. When I select Positioning, this is where you get options to real time gnss corrections. When you let's you select a configuration, you get the option for the primary to be RTK Internet, as well as RTK Satellite. In terms of coverage, are both of these the same it's just that RTK Internet would be faster at real time gnss correction? Or are there other differences?
    The reason I ask is recently I had employees surveying an area that didn't have cellular service (hence no internet). In this case would it be better I just make all surveys done with RTK Satellite ?
    Mitesh Patel
