I am new to the forum and hope I am posting in the right place.
We are currently evaluating a Sitevision AR equipment at work. We work with electrical power lines in Sweden and are now testing to import ESRI Shape in 2D format. What I want is the lines to be draped over the ground. Have tried using Sitevision Manager and set the feature class, geometry heights to ground. It works well if the terrain is flat, but if the ground level is sloping, the lines are drawn straight out into the air.
Is there any solution to this?
The depth of the cables underground is irrelevant, I simply wish to visualize their exact location on the surface.
/Rickard
Rickard Alexanderson
