Hello Kristopher,
It's great to hear you are using Trimble Sync Manager and the Trimble Access pipelines application.
The Trimble Access and Survey Field Solutions Community would probably have been a better place to post as Trimble Access is the field application that Trimble Sync Manager works with. I understand you thinking about the Connect community group in the same manner.
Could you repost in the Trimble Access and Survey Field Solutions Community with some added details based on the comments below.
I am unsure if you mean the date stamps held in the primary tally files for each joint or weld map or if you mean the actual date stamp of the files themselves. If the latter is this on the data collector or in TSM or in the Connect cloud.
Many thanks
Chay
Chay Froggatt
