Thanks, Tom. We have been in touch with our local reseller. We were told that it could have been how we were charging the units (in a multi-USB port charging station). However, after switching to plugging each unit individually into its own wall out (inconvenient with 8 units to charge daily) we have still had batteries that swell. We are trying to narrow down when it occurs to figure out where the problem lies, but my current working theory is that the units just overheat in the field and it causes the batteries to go bad. We currently rotate the batteries because they don't last long enough for a day in the field so it has been hard to track what each battery is exposed to, how it has been treated, and how long we have had the battery. We will track that with serial numbers once we get our new batteries purchased. Unfortunately, those batteries are currently on back order and not expected to arrive until mid-August so we have our fingers crossed additional batteries don't go bad because we don't have any spares at the moment and we are in the peak of our field season.
Sarah
Sarah Hirsch
Sent: 07-09-2024 04:31
Subject: Trimble TDC650 Battery Issues
Hi Sarah
Really sorry to hear this.
If you haven't already, can you raise this with your local Trimble reseller and have them escalate it to the Trimble support teams through the normal channels?
- Any contextual evidence like you have given here around storage, charging and operating conditions will help your dealer, including serial numbers of the units affected and batteries.
- We (Trimble) have robust processes in place to Investigate Issues like this and remedy them at a production level (if required) but only If they are brought to our attention
Tom Harrison
