Hi Vojtěch,
There's a number of packages beyond the scope of my reply here that will help both plan and process UAV (drone) imagery for photogrammetric purposes such as Pix4D, Esri's Drone2Map, Autodesk's ReCap, Trimble's Stratus or TBC and other applications.
Eric Collins, P.L.(Eng.), P.Tech.(Eng.)
Operations Technology, Chief Operations Engineering
Calgary, AB, Canada
Sent: 01-25-2024 10:52
Subject: Trimble X7
Hello Jason,
first I´d like to thank you for any help :).
I personally will not be using it, but we (our company) would like to cooperate with someone on new project and they asked if it is possible. They use drone (pictures taken by it) for photogrammetry survey and they will use our point cloud and those pictures for some calculation (I guess they will pick some pivot points ... not sure what you call it in English). I talked with them, and showed them exported panoramic views, bot those are not usable in photogrammetry obviously. So we are trying to find a way to source those raw individual images from scanner.
I hope I explained it well enough. If not i can elaborate.
Thanks again, and have a nice day
Vojtěch Pětník
Sent: 01-25-2024 07:29
Subject: Trimble X7
Hello Vojtěch,
there is not a way to get the raw images from the Trimble X7. Can you tell me more about what you would like to use the images for? Maybe there is another way to help.
Thanks,
Jason
Jason Hayes
