Hi Norman,
thanks for the info. Then, like ESRI mobile platforms (i'm assuming not only Field maps requires the landscape mode but Survey123 and Quick Maps as well). Good to know TerraFlex isn't operational either on the TSC5 either. Mr. Hoy indicated Terraflex as an option. More importantly, would be the low quality GNSS engine inside the TSC5. A "R1" equivalent EM module (the TSC5 has two available mount points) would make sense to enhance the use of this product in the GIS line.
Joel /23/2023 4:45:00 PM
Subject: RE: TSC5 Could be Used for GIS - Currently not useful
Some more points to recommend the TSC5 for any data capture application are the full keyboard (after using TSC5 for data entry, I hate doing data entry on a touch screen keyboard) and the huge internal battery life of TSC5. Oh, and the light weight of TSC5.
As Hamish says, it's up to ESRI to support Landscape orientation in their applications - but to support the GIS community we should ask Trimble to add Landscape support in TerraFlex as well.
Norman Smart
Sent: 03-22-2023 10:37
Subject: TSC5 Could be Used for GIS - Currently not useful
The TSC5 is marketed to only the Surveying community. We in GIS ask the question... Why just use the TSC5 for Access?
Combine the TSC5 with the EM100 module (basically an R1) in combination with ESRI Field Maps could be put to use, but the screen doesn't rotate to Landscape.
Why couldn't Trimble improve this small update?
It doesn't make sense to make this wonderful controller, combined with a submeter module like the EM100 difficult to use.
I'm cross posting this to the ACCESS community forum.
GIS devices use by well-designed Trimble engineering staff continue to leave GIS users out of the MARKETING LOOP. Its clear we (GIS) don't have the "ear" of Trimble anymore in our device choices.
Please consider this small update as a viable alternative to making the TSC5 only useful for ACCESS.
Here is a photo of a TSC5 with the Empower EM100 module. Would you use this in the field?
Joel Cusick
