WorksManager
TSC7 Remote Assist/AT&T SIM Issues
  • 1.  TSC7 Remote Assist/AT&T SIM Issues
    Posted 12-15-2025 13:25
    Edited by David Kosakowski 12-29-2025 14:09
    I was wondering if anyone had experience with a couple TSC7 issues we've been having with mostly newer data collectors. First problem is that the remote assist feature will not work through WM no matter what I try. I've uninstalled/re-installed remote assist and even wiped the device from WM with no success. Second problem, my company uses AT&T SIM cards and every now and then, we get a new out of the box TSC7 that seems to not have the auto APN configurations installed and using our provided APN does nothing as well. I have updated drivers for the modem/network adapters (all are the Sierra Wireless EM7455B Qualcomm Snapdragon X7 LTE-A) and performed a few basic troubleshooting steps provided in a document, but still only "No Service" while registering it as an AT&T SIM card. Seems to be a hit or miss on which new ones will have this problem and some get resolved with driver/Windows updates.
    Update on the SIM card issue:
    The fix I have found, is to download the "Skylight" application from the Sierra Wireless site, select the first profile (called MBIMModem.......) then in that profiles settings, input the APN (ours is unique not the usual "broadband"), apply, and then input that same APN into the Windows side. Once they match, all is well. Not sure why some don't auto-configure like the others, my guess is some weird Windows compatibility with a select few Sierra Wireless EM7455 modems, but having a solution is good enough for me.
    Evan Murry
  • 2.  RE: TSC7 Remote Assist/AT&T SIM Issues
    Evan, we have reached out to you via email to gather additional information regarding this issue and kindly request you to share the necessary details to proceed further.
    Madhavan B
  • 3.  RE: TSC7 Remote Assist/AT&T SIM Issues
    Posted 12-15-2025 13:29
    I had that happen only once (w/verizon). Had to contact our verizon rep and give them the IMEI# of the device which is located in the battery tray.
    Taylor Weidner
    Tech Mgr
    Hoffman Bros, Inc
  • 4.  RE: TSC7 Remote Assist/AT&T SIM Issues
    Posted 07-16-2026 13:22
    hey, currently stuck on the very thing and was wondering if you could offer more insight? I downloaded Skylight but do not see MBIMModem as the first profile
    We got a all network sim from amazon, as we do not use the data daily
    Al Bernhardt
  • 5.  RE: TSC7 Remote Assist/AT&T SIM Issues
    Evan Murray or David Kosakowski,
    I downloaded skylight, but do not see the profile MBIMModem and thats where I am confused....
    We got an all network sim from Amazon because the Data Collector is not used on a daily basis.
    Al Bernhardt
