Hi Simon and anyone monitoring this thread
The UAV GCP app doesn't currently support the target API associated with Android 13. This is why the Play store is preventing the download and installation
We are still able to provide you with the *.apk to install this locally If you are happy to do this. The app will operate as normal
The update (and fix for this) will be bundled in with some related software releases in the future.
Until then you can do the following If you need to install the UAV GCP app
- Contact your local Trimble reseller
- Request the UAV Ground control app *.apk to install locally
- Copy the .apk to your device - email/cloud file share/cable all fine and tap the .apk to run
- This should install the app as normal, you may be asked to approve installation from unknown sources as part of this process
Tom Harrison
Sent: 10-20-2023 09:16
Subject: UAV Ground Control
David, Tom,
Was this resolved? Hi a DA2 with UAV ground control app and a recent Android phone a good workflow?
Thanks
Simon Gingras-Gagnon
Sent: 05-12-2023 01:40
Excellent. Thanks.
I bought an S20 specifically so I can use this app as I'm ordinarily an iPhone user. Would be good to get this resolved.
Sent from my iPhone
Sent: 5/12/2023 4:37:00 AM
Subject: RE: UAV Ground Control
That's fine David, thanks for this
I'll send you a private message to take this 'offline' to gather some more details.
When we have the solution I'll update this thread for anyone else following
Tom Harrison
Sent: 05-11-2023 11:54
Hi Tom,
Not sure of the best way to reply.
Please see attached screenshots
Sent: 5/11/2023 10:51:00 AM
Hi Dave
Can you confirm your Android OS version please (SETTINGS > ABOUT PHONE > SOFTWARE INFORMATION) and the date of the last security patch applied please
If you just want a csv output of control points the UAV GCP app is the best option here.
Assuming you have a Catalyst DA1 or DA2 , the other compatible software we have that would fulfil the task of capturing high accuracy GCP and outputting to csv are Trimble Terraflex and Trimble Penmap. What I would say are that these are both professional GIS Data Collection and Hybrid Survey software packages so will be 'overkill' for your task. The cost also reflects this
Lets start with your OS details and see If we can resolve this with the UAV GCP app
Tom Harrison
