Sent: 08-24-2023 09:47
Subject: UAV GROUND CONTROL - can't share
That's not the problem. It's installed on the phone and we used it fine with the DA2 as advised. However the app does not let you copy the data out so it is now stuck in the phone,
If you are from Trimble, please can you advise on what app we should be using with new DA2 system or have we got to buy an old phone to use with it?
Many thanks
Chris
Chris Davies
Sent: 08-24-2023 03:07
Just chiming in here from the Trimble side
The Trimble UAV GCP app is not available for any Android version later than 10 but you should be able to download and install this directly via Play on Android 10 and earlier
We're aware of this and hope to update the app to enable 'Play' support for all versions In future or provide an alternative solution
In some cases your local Trimble reseller may be able to help facilitate the installation of this app directly, If you reach out to them
Tom Harrison
Sent: 08-23-2023 14:48
It's the UAV Ground Control App that you have to use with Trimbles Caralyst receiver. It's super basic and costs £10 !
it's not been updated since 2020 and doesn't work with new Samsung phones by the looks of it
Chris Davies
Sent: 08-23-2023 09:41
Hi Chris, on a side note I was curious about what app you are using. I have a customer needing a simple ground control points
Thanks
Doug
Doug Kotnik
