It would be good if Trimble connect used the software set units and if no unites were specified then the the default should be meters. Or even better , during import , there is an option to check the units and even change the units or add units if its missing.
Defaulting to feet is not the way forward.
Andrew Newmarch
Sent: 10-14-2024 01:10
Subject: Unit Settings (Defaults and Object Properties)
it is 2024 and trimble connect have not fixed unit system error.
I would like to use only trimble connect to open and measure small connection models in case if I could set my default unit system(for me metric), but trimble connect keeps open all models with imperial unit system and steels my time to change it back again and again.
Agris Missa
Sent: 12-12-2022 08:45
This can lead to manufacturing errors so would absolutely like the default units for new projects to be read from somewhere. Many times Trimble Connect project is started directly from Tekla Structures too, you can't choose a template when you do that.
Best Regards,
T Laine
Sent: 12-11-2022 20:20
Hi Heber,
Unfortunately , its not possible for a user to set unit type in Trimble Connect globally across all projects.
One option is - if you are creating the projects, you could use "Use as template for a new project" => "Project Settings". This will copy the unit settings to the new project being created.
Darshan Rajaram Kamat
