@Veronica Sew this could be a good option for us! I didn't realize the authenticator app we use (Microsoft) could be used to generate codes locally. Thanks for the suggestion!
@Scott Weber using the Google authenticator app would be the same concept, but we'll stick with the Microsoft one since we're already using it.
Jamie Maxwell
Sent: 03-06-2026 10:01
Subject: Upcoming 2FA change workaround?
Our organization found that using an authenticator app is working for us. When you set the 2FA in https://myprofile.trimble.com and choose the Authenticator option - save the QR code image and share it to your team members. This QR code will generate the same code across multiple authenticators
From a Trimble bulletin:
For shared accounts, we strongly recommend using an Authenticator App installed on the shared field controller itself. This allows any crew member using that specific device to generate a code locally without needing access to the central email account or a personal phone.
Veronica Sew
