IF you want to send me your file, i could have a look.
Sent: 03-26-2025 14:28
Subject: VCL Designs in WM
Good afternoon,
I've published two VCL designs today, but the LW isn't pushing over-only the surface. I've been pushing VCLs for a while now and can't figure out what's going on.
Is anyone else running into this issue? The LW shows up in the WM viewer, but the tablet only receives the surface!
Jason Smyth
Sent: 03-18-2025 09:40
Your warning about too big surfaces can not be made loud enough. If you happen to include a surface, either directly or by reference, that causes the vcl file to exceed 150 MB and you send that to WorksManager you will instantly brick all the EC520s connected to your network at that time. The size limit is not exactly 150 MB, but somewhere between 150 and 600 MB. 150MB is what they tell me is safe. There will be no warning before it happens. You will have to replace every unit that was connected. This is a built in flaw that Trimble is aware of, and is one of the many things they claim to be working on fixing.
Wayne Welshans
Sent: 03-18-2025 07:31
We only use VCL files in both SW and WM created from TBC to WM work flow. Look at the cad objects in "advance select" and make sure that you convert or delete any leader lines, ellipses, blocks etc. before export. You may still get a linework error in EW on loading the file but it will still function. The only issue we had recently, is if you have a surface that is dependent on a very large tin model, it will not load in EW. I that case "offset surface" vertically zero and the dependencies will be detached.
Thomas Mauriello
Sent: 03-17-2025 08:25
This is from what i was told, that not to use the VCL as the machine did not like them. So i tried it for the field crew data collector. And somehow the machine tried to pick it up and the job Site would not load.
Francisco Guerrero
Sent: 03-17-2025 08:10
Are you talking about the thing it does after loading some VCLs where the Job Setup window won't let you select the design for several minutes?
Michael Brennan
Sent: 03-17-2025 07:29
Has the VCL option been fixed for the machine control? There has been issue where it will freeze up the Site and not let you open the Site. I have even run into the issue where I had a VCL for the data collectors and it affect the machine control Site. We had to remove the design from the TCC files.
Francisco Guerrero
Sent: 03-17-2025 04:47
Michael, Wayne is correct. Instead of selecting "surface" on your design export from TBC, use the "User Defined " option, pick your surfaces from the Project explorer tab. All of the surfaces will be in VCL and multiple surfaces will be available on earthworks machines.
Thanks, Tom
Thomas Mauriello
Sent: 03-13-2025 06:54
I've been getting frustrated with this lately. It's convenient that WM can synchronize devices over the air, but without VCLs it's getting to be rather pointless. We use VCLs for our devices because they can hold more than one surface. An operator running Earthworks can select which surface they are working on within the same design. This helps save the design list from becoming 50 items long, which keeps us sane because we're not getting calls from Dozer operators all day saying they can't find the design they're supposed to be using. WM does not support this multi-surface functionality, but it really needs to. If we have to go out in person to these machines and upload each one anyway, there's not much reason to continue using this service.
Michael Brennan
