Hello Dave.
When you see 0/0 forms in task, this usually indicates that you have not published a Template for this Layer in Map Viewer.
To do this, after importing the file to Map Viewer, you then need to select the icon in the the Data window that says "Add":
This creates a new Template from the imported Layer. Once you have published the Template, you can then select points/lines/polygons in the map and generate a ToDo. You should then see something like 0/4 forms updated in Terraflex (rather than 0/0 forms updated).
Kim Bilton
Sent: 01-13-2022 21:46
Subject: Re: Viewing imported shapefiles on TerraFlex
I select the points on the map but the todo doesn't list them just get 0/0 forms most frustrating
Dave Humphreys
Sent: 03-26-2020 09:03
James,
Hi, this is done via creating a "ToDo" aka Task.
See my screen shot.
