Hi Jon,
thanks for your feedback.
I don't think that the elevation change is related to the issue I mentioned above with the DA1.
Can you please provide more information about the antenna you are using and the Penmap project where you have seen the change?
Please send the project directly to
penmap@trimble.comPlease describe the points where you think they should have a different height.
We will have a look at it and come back to you.
Thanks
Thomas
Thomas Schucker
Sent: 12-06-2022 11:50
Subject: We see issues with a couple of Android 12+ devices connecting to DA1 with Penmap 11.9.0.2576
Hi - I'm in Wisconsin, USA and using Wiscors for RTK and since the update it appears that when connected to wiscors the elevation is around 3-ft to 4-ft too high. Using Penmap for Android Version 11.9.0.2576 and a Samsung Galaxy Tab 6. Thought I'd mention to see if this may be fixed with the above issue.
Thanks
Jon Bublitz
