Hi Gavin
Two options here (assuming you have no Trimble desktop software):
Trimble Mobile Manager - like Mark said the Ausgeoid2020 Geoid is included under geoid option when configuring your GNSS Output
- In the TMM app go to the GNSS Configuration menu and configure your GNSS Output
- When you select ausgeoid2020.ggf from the geoid list, the *.ggf will download locally to the device for use in TMM AND be available through your file browser copy/send to your PC
- iOS - ....Files app\On My iOS device\Mobile Manager\Geodata
- Android - ....\Internal Storage\Android\Data\com.trimble.trimblemobilemanager\Files\GeoData
Alternatively you can install the the stand alone TBC utility Coordinate System Manager 64-bit (June 2023) on your Windows machine
- Once this is installed the geoid will live locally C:\ProgramData\Trimble\GeoData\
As your are working with Grid factory the TBC utility will probably be easier
Tom Harrison
Sent: 07-03-2023 21:57
Subject: Where can I find ausgeoid2020.ggf?
Thanks Mark.
I need to import in to Trimble Grid Factory to create a subGeoid, and will then use the smaller/modified ggf file in Trimble Configuration Toolbox to create a CFG file to apply to our receivers.
Gavin Williams
Sent: 07-03-2023 20:58
Hi Gavin,
What software are you wanting to use the geoid with? If you are using Trimble Mobile Manager the geoid is built in to the application.
Regards,
Mark Kellaway
