I did not see the ability to only sync certain designs. I will look into that shortly. We just hit the worksmanager button on the tablet and it does everything on its own I thought.
I found the logs, they show that it downloaded the new version of the file, and then the old version 9.
Rich Smith
Sent: 04-02-2024 15:45
Subject: Works Manager is restoring files to a T7 that were deleted
Rich,
hello!
Version 9 may be stuck in there for some reason or another. Typically, if the newer version is no longer available in worksmanager, you should be able to do a sync through the collector and choose "design" sync. Sync version 9 specifically and if it is no longer available in the cloud it should prompt you to keep or delete the local file. If it does not prompt you, it is still in the cloud and you can get rid of it Via the trimble connected community root file access.
hope this helps.
Alejandro Banuelos
