WorksManager
WorksManager Feature Requests
  • 1.  WorksManager Feature Requests
    Posted 02-22-2026 21:25
    Some feature requests that would make managing/cleaning up data significantly less of a time suck:
    1.  Archive work orders from a device
    • Function - should be able to remove work orders from a device but have everything archived within WorksManager.
    • Use case - less data stored on a data collector for the user to sort through, but also less data living on the device and bogging out a controller on multi-year projects, or simply projects that require a lot if workorders in a day. Also makes year end cleanup significantly easier.
    2. Unassign a device from multiple projects at once
    • Function - should be able to click on a device, view a list of projects on the device, select the multiple projects that they want to unassign the device from at once, then click unassign to remove them from the controller
    • Use case - Extremely fast device cleanup at the end of a season. It's painful the amount of clicks it takes to do it right now. And you have to be assigned to the project to be able to do it - which inevitably adds more clicks...
    3. Batch sync all projects/data from a device (say within Siteworks) to Works Manager.
    • Function - Say within Siteworks, you should have the option or All Projects or All Data when syncing to WorksManager. Selection location would be where Project, Design, and Workorder are currently found.
    • Use case - to make sure you synced everything whenever you heart desires, pretend you were on ten sites that day, or you just want to make sure everything is current before cleaning up a device at the end of the season.
    I'm sure I have more, but these are the most aggravating things while trying to clean up devices during the off season. It takes a ridiculous amount if time that could 100% be better spent doing other things...such as chargeable work.
    Thanks!
    Chelsey Scora
  • 2.  RE: WorksManager Feature Requests
    Posted 17 days ago
    Hello Chelsey, Thank you for your feedback. Your second ask about 'unassigning a device from multiple projects at once' has now been implemented. You can access the feature from Account > Devices page > Select a device, and you will see a new label 'Project Assigned'. You can then remove the device from any/ all the inactive projects. A small 'green' icon gives you an indication if the device is still active in a project
    Vijay Raghunathan
