Thanks Adam/Ben. The bases have come back online themselves overnight. Not sure what the issue was but obviously it didn't just affect our bases.
Sent: 05-20-2024 03:53
Subject: WorksManager / IBSS bases offline?
got all mine back up with a reboot
Ben Brown
Sent: 05-20-2024 03:48
OK thanks. I'll do a few more tests and see what happens. Hopefully they will reset themselves and come back online by morning when the operators fire up the machines.
BradS
Sent: 05-20-2024 03:36
Yes, I'm lucky enough to have maintained remote access to the WebUI for 3 of the bases. I would imagine you would need to connect a laptop to get to these settings.
Adam Procter
Sent: 05-20-2024 03:30
OK thanks Adam. I'm guessing you mean that you are changing the IBSS setting directly/manually on the front panel of the base and not remotely? The 3 bases I'm having issues with are 45 minutes south-east, 2 hours north-east and 2 hours south-east of me!
BradS
Sent: 05-20-2024 03:18
Brad, still showing offline our end. I've gone to reset / change the IBSS configuration, in the hope a refresh may work. I've found that if you deselect 'IBSS Mode', the base appears back online. It doesn't seem right, but appears to work if you're desperate.
Adam Procter
Sent: 05-20-2024 02:15
Got a direct response/message back from Trimble to a message I sent and the response was "We updated the IBSS security certificate a few hours ago which caused a downtime for nearly 5 minutes, which was unexpected. It was back and working fine. We apologize for any inconvenience." Not sure what that specifically means at the moment so I'm waiting for a further response on what to do as the bases are still offline.
BradS
Sent: 05-20-2024 01:48
Same issue with us - lost 4. They show the status: Verification of NtripCaster SSL certificate failed. I'm thinking it's a sim issue, with one of our IBSS bases functioning fine on our office network.
Adam Procter
