Hello Sir,
1 I found that opening all nwc files. the API returns an error message. It is not working properly. What is the reason for this?
2 In addition to this, some rvt files open with the same problem. Since this is an error returned in the API, I'm not sure how to handle it.
3 I tried uploading the model using a plugin in Revit and got the same result
Would you offer any help?
