Recently started using connect and i am having an issue where connect is only showing wire frame views for duct work and not populating fittings. is there anyway to view in 3D and fix the fittings?
Hi Nathan, Could you please share the 3D model with our Support Team (connect-support@trimble.com) so that the team can investigate. RegardsDarshan Kamat
