Hi @Laura Cook
I have found out the reason why this "error" occurs.
- Here is the GUID of an issue exported from Trimble Connect: 453c1aaf-56f5-4b1c-9028-5b52d5229e60
- Here is the GUID of the same issue when exported from ArchiCAD: 453C1AAF-56F5-4B1C-9028-5B52D5229E60
The only difference is that Trimble Connect uses lower case letters while ArchiCAD uses upper case letters. I have experimented a bit by unpacking the BCF file, changing the GUID and then repackaging the file and can now say with a fair degree of certainty that the problem occurs because of this.
Cheers,
Lucien
