 Curved wall is not displayed correctly Trimble Connect
Alexander Schlachter's profile image
Alexander Schlachter posted 07-18-2023 22:52
I'm exporting a curved wall form Revit as IFC and use it for coordination with the project in Trimble Connect.
However, we experienced that the curved wall is not displayed correctly..
The wall is split in straight sections of a specific length (~12m) and does not contain door holes.
If opening the same model in Solibri, it works fine.
Trimble Connect:
Solibri:
Is this a bug in the software or is there any setting to change for displaying curved walls correctly?
Thanks for the help :)
Darshan Rajaram Kamat
Hi Alexander,
Could you please try the Edges settings (Screenshot below)  in the Settings panel to see if it solves your issue.  If it doesn't solve the issue you are facing, could you please send the model details to our Support (connect-support@trimble.com) .
Darshan Kamat
HI Darshan,
Unfortunately this doesn't change anything for the geometry of the wall, only displayes the *edges, as the function also describes.
What do you mean by sending the details to the support team? Providing the model?
Hi Alexander,
Yes, please send the model to our Support team , so that our team can investigate.
Darshan Kamat
Hi Darshan.
Thanks for the quick reply. I've sent the model to your support team. Hopefully they can help.
