Hi All, I have just upgraded to TC desktop Version 1.19 and am having issues.
The back story....I have a Revit 2021 project with a building split North / South, I have three models Arc Str and MEFH.
I split the Arc and Str files into two exports N and S the MEFH Model I had to split into N and S for each discipline (ten Models) 14 models in total
I used the Trimble File uploader from within Revit, and they uploaded fine.....Or so it seemed
If I select the Arc N and S Models they both show as South Arch model
Same happens if I select the Lighting Model
When I select the Containment models it displays the Lighting Models
Hydraulic displays both as the North Hyd Model
and Fire models display as the Hyd Models. Both North...
Str is the only one which displays correctly.
I have invited another user to test and it is the same for them?
Please don't make me go back to Navisworks! :(
Using the Web version, all is as it should be.
Trust that all made sense?
